E39a checksum issue
I pulled the file on a 2014 Cadillac ATS 2.0 to turn off a few CEL (like an idiot i did not save the untouched file) i changed to codes to not reported and tried a cal flash. The truck flashed until the end then said it had a checksum issue and no longer will start. Is there a fix or is a nee ecm needed?
1 Attachment(s)
Does the ECM respond to any requests? Can you get the part number off the ECM?
Would look like the attached in the tune.
Attachment 24567
If that matches, I could send you the stock cal from my wifes 2015 Malibu 2.0t. 12653998 does show as compatible with a 2014 ATS 2.0t. The calibration probably wouldn't be exact, but it should work if the part numbers match.
