Im trying to open pids for my aem wideband in scan tool but am unable to find them. I just see others , like plx,lm1, f.a.s.t, etc.. Is there someplace to download them? Thanks
What version of EFILive are you using?
AEM is the first WBO2 on the list.
You will need to select EXT.AD1/2 for it to be valid.
Uncheck the supported box above the description column.
im using the latest version of efilive 7.5 with flashscan v2 and got it connected through serial
im using version 7.5.5 build 83. The first wideband i see on the list is autronics.
If AEM is serial. then you will need to select the serial PIDs
EXT.WO2AFR1
EXT.WO2EQ1
EXT.WO2LAM1
EXT.WO2ST1
and select the WBO2 in the V2 itself,
F1> F4> F4 scroll to WBO2 type> select AEM> OK
Ok found all of those except EXT.WO2EQ1 . Where is that one located?
I got it working thanks!
Post some logs...:cheers:
trying the auto ve tutorial, here are the logs. car is 2000 camaro with 2002 OS, with lid, long tubes, tr230/224 cam. Can you guys look at the log and also let me know if my o2 sensors are working?
