I see OS5, and it appears its mostly for Boost/nitrous. But, what do OS's 1-4 do? I searched but couldn't find a description of each.
A breakdown of each OS's features would be super. Thanks guys.
These are the major highlights as I recall
COS1
restored dual spark maps for running in SD
COS2
Same as COS1
Added Valet mode
COS3
Same as COS2
Replaced B3605 (ECT vs MAP OL Fueling) with B3647 (RPM vs MAP OL fueling)
IAT VE multiplier
ECT EQ multiplier
Added Boost VE table
Added Boost Timing tables
COS5
Same as COS3
added TPS vs MAP VE table
additional functionality added for PCM Pin 56.
This is the best my memory serves, which is rather shaken with the RTACS announcement, so feel free to correct me.
edit: corrected per Tordne's post
Only correction: Boost VE and Timing is a COS3 function. Otherwise looks spot on :)
Muchas graciasQuote:
Originally Posted by Tordne
Thanks guys.
TA, I copied the COS summary into the OS FAQ sticky thread....
or, should there be a separate sticky for COS features...?
Feel free to move/organize it.
Good spot for it. Mind helping me to better organizing it?
Ok, we can sort it by question, have a seperate post per question within the FAQ thread, something like that.Quote:
Originally Posted by TAQuickness
I should scour the forum threads to collect any scattered COS information into the FAQ thread.
I'd actually like to get on a conf with you two (joecar and TAquickness) and work out a good structure for this sort of stuff. I think it will get pretty ugly with stickies. I quite like the LS1TECH stickies that refers to different posts.
Tell me when. I'm off for the next 2 days.
