Newbie Question: LQ4 Silverado Tune from AT --> MT <?>
Hi Guys
New to EFI LIVE, reading and learning alot, but I've come to an impasse and need some help.
I'm finishing up a swap into a '00 S10
Donor Engine:
2005 Silverado 2500 LQ4 6.0L
DBW , Pedal, TAC Module, all from 05 Silverado as well
Transmission = T56 from '00 Camaro
Problem:
I'm operating on the OS and tune I read out of the truck ECU. But it's for AT, so while I disabled all of those things, as best I could, it still has some rev - hang and DFCO and driveability just isn't right.
I'd like to switch to something that is an Manual Trans, preferably a 6.0L of the same generation like GTO or CTS-V
1) Does the OS need to match from my current to target calibration? Because I can't find anything that has the same OS, is 6.0L and Manual Trans.
2) Should I do a segment swap from an MT vehicle? I have some some .tun files that have the same OS, like Corvette I believe, and are Manual Trans.
3) In what cases would I need to do a Cal-Flash vs Full-Flash? Can I change OS w/ a Full-Flash?
Thanks for the help!
