2 Attachment(s)
Some driveability issues and idle swing
So, I feel like I can get more out of my tune than I have right now, but that can be discussed further along in the thread.
Right now, I am having a couple of things that bother me with driving the truck. The first is that when I am in gear and rev to a high RPM, then as it falls back down to idle, it has a hard time regulating the idle. Sometimes (if I rev too high) it will actually stall coming back down to idle.
Secondly, it does this every time when I have the A/C on. I have played with the idle air tables like crazy. My VE is in line. This leads me to believe it could be something with the timing.
I have turned off the {B4358} A/C Torque Loss Spark Correction with no difference. My mods, log, and tune are below.
- 2001 LQ4 bored and stroked to 408.
- 317 Stock Heads with Comp Lifters and Comp Springs
- Wiseco dished 4.030" 9.5:1 CR pistons
- Comp 230/238 .600 .603 @ 114 (Spec'd by Comp to maintain towing ability)
- Melling High Volume, High Flow Pump
- Cloyes single timing set
- All new sensors in the block.
- Whipple 2300AX (about 6psi now)
- Fully built 4L80E
- Circle D 278mm 4L80E Torque Converter 2800 stall
- Tru-Cool 40K Transmission cooler
- 1000cc at 43psi FIC Injectors, so with manifold referenced they are about 114lb/hr @ 58psi
- Pacesetter 1-7/8" LTs Tri-Armor with true dual 3" custom system
- Volant CAI with Scoop
- Intercooler Kit - CX Racing 31x12x4
- EFI Live V1 going to COS3 and SD tune.
- 34" Radiator w/ '05 Efans
