This one is for Ross and Paul
OK,
Truck: 06 silverado LBZ
V2, 7.5.4 build 62, 8.1.1, June 12 v2 firmware.
Problem, Flashed a tune in both tranny and engine and it pops up with the MIL. pulled codes u0116 and b0283. I took a while to read the codes. with just the flashscan i was getting intermittent $0281 error. Tried doing pass through to read the codes and the scan program is saying some modules did not respond. it want tell me which ones. in the modules tab it says it detected $11 and $18 the tranny and engine controllers. when i connect just the v2 it detects ECM TCM and something called GPM (i think).
So now to the weird stuff: So the code B0283 is rear defrost heater circuit. The only way i have had to read the code is with BB. I have just discovered that when i plug into the truck it says CAN but when i select the LBZ auto pids it switches to VPW is it supposed to do that? I have just discovered today that if i read the code without selecting the LBZ pids the code comes out P0101 (mass airflow) but when i select the LBZ pids the code comes out as B0283. I think i have found that the reason the code was thrown in the first place was that in my last tune i have played a little with the MAF voltage translation, maybe a little too much.
So i will flash in a revised tune with the MAF table back to stock and see if the code returns.
But whats the deal with it displaying different code numbers? and why is the scan program saying some modules did not respond?
