how do i build a histogram in efilive or is called something else
and if where do i find it and start ?
thanks
thanks
It is called a "map"...
how to create a map is explained in post #1 of this thread (find the CALC VET Summary Notes link): Calc.VET
Basically :
You copy-with-labels a table in the tunetool (say B0101)...
then in the scantool, on the Map tab, click on a map letter (say A),
click the Edit map properties button,
on each of the Row and Col tabs click Paste Labels,
on the Data tab checkmark Names and select the pid you want to map,
on the Data, Row, Col tabs checkmark Show Units,
save the map (give it a meaningful name).
The Calc.VET thread references this thread: CALC-VET-Summary-Notes
see: II. Scan Tool Setup -> 2. Creating maps
thanks Joe
HUMMM not sure what thats about looks a bit complicated for an old guy :doh2: lots of reading i guess ? any one send me some all read done to work on ?
cheers
Ok, read this: scantool user manual pdf, pages 128-131.
Then do this:
In tunetool:
- choose the table in the tunetool that you want to make a map of (say B0101);
- then click in the upper left corner tile of that table, and go rightclick->Copy-with-labels;
In scantool:
- click on the Maps tab,
- click on a map letter (say A),
- click the Edit map properties button (looks like a hand point at a white sheet of paper),
- on each of the Row and Col tabs click Paste Labels,
- on the Data tab checkmark Names and select the pid you want to map,
- on the Data tab checkmark Display Type,
- on the Data, Row, Col tabs checkmark Show Units,
- save the map (give it a meaningful name),
- click Ok (exits the map properties window).
When looking at a map, the n button shows the cell hit counts, the x-bar button shows the average value of each cell.
You may need to filter the data... do this:
- in the map properties set the cell empty count,
- set up a data filter (click the filter button (looks like a hand pointing at a grey oblique parallelogram)).
i will give it a go thanks heaps
mate cheers
Let me know how it goes (post some screenshots).
HI Joe
so far i have got a couple off map pages up (i think ) and when i run one of my logs it puts # in cells ?? gotta do it slowly as i get confused at 70 Years old :ermm: my biggest problem is not knowing what MY BEN are i guess im just using the generic program ones ?
i gotta do a lot more reading
cheers Bob
Hey Bob,
No worries, I'll walk you thru it...
which wideband do you have...?
do you have FlashScan V2 or V1...?
Are you able to take a screenshot and post it here...?
See this for how to do this: Hosting-an-Image
