Any SD card will work correct? I found a 4gig SD at newegg.com for $39
I'm pretty sure it will only recognize up to 2 gig cards, which is WAY bigger, then you could ever fill if you never deleted anything from it, lol. Ross recommends a couple 512 meg cards, so you don't have to have everything on one card. Plus 1 512meg will hold tons of tunes and days of data logging. I think 1 tune in your truck is 2 meg and most data logs are a bit over a meg an hour depending on how many pids you logging.
Ok.......I have a slight "if this is good, than this is way better" problem.......:Eyecrazy:
lol, I know what you mean ;)
