I just upgraded to OS5 in my camaro. Is there a way to run a trans brake, and nitrous off the stock pcm. I want the nitrous to come on when I release the trans brake.
In short, yes. I would use a double pull, double throw relay to the transbrake and the N2O. I have one foglamp switch rigged up to a double pull, double throw relay that is hooked up to my WOT sw and Pin 56 of the red connector on the pcm. So, when I go WOT the relay applies 12v to the WOT relay/switch and a ground to pin 56 for the COS stuff. I don't see why you couldn't include the transbrake switch.
