408 going in, base tune for initial fire-up
Guys, I don't post much but I read a lot! I think here on this board are some of the smartest people with experience from whom I have learned enough to have tuned my H/C car by myself.
I have a 408 GM LQ9 iron short-block going in and need some ballpark adjustments to a stock 2002 LS1 tune for initial fire-up. From everything I've read and heard, the first couple heat cycles are critical to seating the rings and all that. So I don't want to spend time dicking around with a stock LS1 tune to ballpark A/F and timing so the car will run right for break-in.
I already have done the calculations for IFR table and displacement/cyl. But need to know what adjustments to VE might help aside from the 60%-70%-80% in the low-RPM (400/800/1200 RPM columns). Or maybe other tables that that need adjusting.
Anyone out there can share some of their experience doing this right the first time?
I use LS1Edit for programming and EFILive v7 for scanning, but even if the info is in HP Tuners values, I'm sure it can be converted to LS1Edit values...Thanks guys.
Engine configuration is:
- Compression 11.4
- Forged rotating assembly w/Diamond -10cc pistons
- FAST 90mm intake/90mm TB
- SLP 85mm MAF
- Stage II LS6-style CNC ported heads 59cc chambers
- 42# injectors.
- 25% UD pulley
- Texas Speed "MS3" cam (237/242, .603"/.609" 112LSA)
