I thought the innovate lc1 only reads up to like 22 afr? I logged my diesel yesterday and it read up to like 85:1 afr
I get the same with my LC-1's through the serial. I think with the 0-5 volt analogue you are limited due to needing reasonable resolution with a finite voltage range.
85:1 is not uncommon with a diesel. Don't know any specifics with the LC1.
Tim, are you reading the LC-1 using serial comms...?
Is it showing lean after a rich reading?
Do you have a log?
It look like it's reading good just didn't think it was meant to read that high. But like you said it's the analog that wont' But after looking at the logs I really don't see how using AFR on a diesel will help lol. Maybe on WOT but it seems useless on anything less than that.
