Some posts say it's a 2.5bar 260kPa sensor.
Some posts say it's a 2.0bar 210kPa sensor.
TIA.
TIA.
http://www.robietherobot.com/storm/mapsensor.htm
Yea I see what you mean...
12580698 It's actually the BARO sensor for the [04 Saturn] Redline and the 05 cobalt. Correct part number though. 2 BAR, same physical package at the stock 1 BAR sensor. The MAP sensor on the ION/cobalt is 2.5 BAR w/ built in temp sensor. The packaging and connector is different however.
(http://www.ls1tech.com/forums/showthread.php?t=310536)
For up to 15 lbs boost - plug & play:
2.5bar:GM P/N: 12580698 AC Delco: 213-1631
PN# 12223861 3bar MAP
PN# 16040609 2bar MAP
PN# 16137039 1bar MAP
(http://www.hptuners.com/forum/showthread.php?p=60692)
Photo and info:
http://forums.corvetteforum.com/show....php?t=1330753
More info:
http://www.pacificp.com/forum/viewto...e85eeae64bc457
http://www.ppepower.com/forum/viewto...abdfcac7a21472
http://monodax.com/forums/tunercat-j...ml?t-549.html=
Hmmm, Maybe with a 5 volt reference source and a 50PSI air tank with a good digital tire gauge you can plot the output curve vs. PSI...
It's a 2bar baro sensor from the ION... least that's what I was told on tech before I bought one (in the same link posted above).
You guys are right!
Talked to a Delphi engineer.
20-200kPa
Only a 2 bar
This is a BAP sensor for the SS Cobalt/ Saturn Ion....not the map sensor...can be used as a map sensor (I'm using one now), but it is not 2.5 bar.
The Cobalt SS also uses another combo MAP/IAT sensor that is 2.5bar, hence the confusion.
