Hey, Im about to get FLT IV trans mission installed and the problem is I dont know where and how to change the line pressure to stock. Can someone show me where to go in order to change the line pressure?
anybody??
First you need to have a stock file to compare with. If you do not have an original file from your PCM before any modifications, check HoldenCrazy.com for one. Load your current file and then use the stocker to compare with. Note any changes in the transmission area of the program. Shift points by RPM and/or vehicle speed do not matter. Anything that has pressure or shift TIME will need to be matched to the stock file.
Al
So just to make sure, under category transmission, there is General, Shift at Speed, RPM, TPS, TCC, Trans Pressure, Desired Shift Times and Torque reduction.
The ones that I need stock is Trans Pressure and Desired Shift Time is that right just to make sure so that I wont break my new trans?
Do a compare and see what is actually different. There might not be too much. If you are unsure, post both files.
Al
which one is what im asking.
Post your tune file and the stock tune file.
herer is the tune
Attachment 4508
here is the stock
Attachment 4507
The only tables that are pressure related and modified are D1108 and D1109 for the 4.10 TM Stock Pressure.tun vs. 02 LL8 Stock PCM.tun. Is that your newest file or is it 3tune1_update1.tun?
You may want to check with FLT on their Torque Management requirements if any.
Al
