V5 "better" than V6 - what about V7?
I have seen a few posts where V6 won't connect or function with as much features as V5. If this is this true, why?
Will this be remedied in V7?
Regardless of "Enhanced PIDS" I would EXPECT ALL EFILive versions to function as a "generic" OBDII scan tooll, and whatever enhanced PIDS are common across various GM lines, to be supported equally on each vehicle.
I presume it's a software limitation as the B&B interfaces are unchanged between versions.
Will the Flash Scan interface present any problems with compatibility with"other than LSX GM" cars?
Anyone care to clarify?
MRK
