1998 LS1 Camaro 5.7 Stand-alone harness???'s
I'm working on a project and I got a couple of questions... I need to build a stand-alone harness for a 98' Camaro 5.7 engine, If I use the pin-out/schematic from a 99-2002 LS1 & use a 2002 0411 PCM will it be fine? Or do I need to build the harness using the 98' pin-out/schematic & 98' PCM only? I'm thinking I should be fine but I want to make sure...:D
The engine doesn't have stock harness or pcm... The engine & sensor's are identical right? The 98' PCM & Harness are the only thing's that changed(different location of sensor's on pin-out) from 99-2002...:unsure:
