got a car that has a commanded idle issue. its a 70 implala swap with a current performance harness
in park the commanded idle follows the in p/n idle table when you shift it into gear it goes to 896 rpm commanded no matter what you set idle speed in gear at,
car came from another person whe chopped all the tables up chasing the issue and the first thing i noticed was the commanded idle rpm problem
any thoughs
thanks
Attachment 18191
Attachment 18192
