1 Attachment(s)
E38 Calc Ben requires fixing?
Is there anyway to have the calc ben's for e38 calculate off lambda instead of afr?
My innovate mtx-l's can be programmed to different fuel's and different outputs. i.e lambda/afr and i have them display lambda on the guages.
However i've found that if i leave it set to petrol - 14.68afr.
because im running ethanol with say a 80% mixture the ben's are completly up the shit. i.e saying 1.38+ because the commanded goes to say 9.43 and the WB-Serial afr says it's 13.63. however lambda is correct at .913.
Attachment 15907
