The June 2014 public pre-release software is now available.
Please download and install both the V7.5 and V8 software packages.
Download V7.5 Software (92 MB)
Download V8 Software (45 MB)
Release Notes:
Known Issues:Please post issues, questions, clarifications (large or small) in this thread.
As issues are reported and confirmed they will be re-posted as "Known Issues" below.
- A40 tune files, when loaded into the V8 software will sometimes show that the OS check sum is incorrect. The display should show "N/A" for the OS check sum in that situation (fixed in next update).
- E20 tune files cannot be loaded into the V7 or V8 software (fixed in next update).
Version Numbers:
After installing the latest release you should have the following software, boot block, firmware versions installed:
EFILive V7 software: V7.5.7 Build 257
To view the installed version, select Help->About (in the V7 Scan or Tune software).
EFILive V8 software: V8.2.2 Build 250
To view the installed version, select Help->About (in the V8 Scan and Tune software).
Boot Block: V2.07.07 (Feb 07, 2014)
To view/update the Boot Block, Click the [Check Firmware] button in the V8 Scan and Tune software.
Firmware: V2.07.60 (Jun 09, 2014)
