just installed 7.5 but now the scan tool when linked to the tune tool will not track the maps.
trying to tune ls2 with a can and e67 pcm
any help out there
rapid:bash:
any help out there
rapid:bash:
Some of the PIDs are actually labeled with E38.APCYL_DMA and not E67.APCYL_DMA
Try to select the E38. version and see if it tracks.
I assume the actual address is the same so while it is a label problem it may actually provide the correct information.
Also if that's a bug then also the CAM Position *** Tables all start with 0.80 for E38.APCYL_DMA instead of 0.08. I assume it's a label issue and just ignore it. Because that's how I roll..
