2 Attachment(s)
Performabuilt Lvl 2 4L60E Not Shifting at Desired Points
Hello,
I am running a Performabuilt Lvl 2 4L60E in my Procharged 99 T/A. The car is running good and the trans is great but, I can't seem to get it to shift 1>2 and 2>3 at the desired points. Basically, I want it to shift at 5900 to 6000 rpm. No matter where I set the RPM or VSS points, it shifts + 4-5 MPH and 200-300 RPMs over the shift point. I have shift times set to 0.3 seconds on both shifts.
I have attached a tune and log from this morning. It also shows a couple of lean points under boost which I have adjusted for.
In short, how do I get it shift when I want? What am I missing?
Thank you
