3 Attachment(s)
Working on Calc.VET tune and getting odd data when logging
I have setup 7.5 as instructed and I pulled the CALC.VET in the latest thread about this method. When selecting this PID file and logging data, I get duplicate fields in the DATA section of 7.5.
Attachment 13661
There are duplicate entries for a couple of the PIDS, even though they are only enabled once.
Calculated VE - BEN corrected - the second one has valid data present, the first one stays at 0%??
If you look at the Dynamic temp fields, they are not really valid values for the label (F) -357 degrees?
DAT appears in the list twice, the second entry carries the proper Temp value - why is it showing two entries??
Don't want to use invalid data when tuning, so I need some clarification as to what might be going on here.
Log file and CALC_VET.PIDS file are attached.
Any help would be appreciated
