Surging when coming to a stop
I'm new to EFILive, I've been reading thread after thread on idle tuning and my head hurts!! I have a 2000 Trans Am A4 with a 222/228, .551/.551 cam on a 115 and a Yank SS3200 converter. After the cam install and idle relearn the car will start up fine, idle fine in park/neutral whether it's hot or cold. Hot restarts are fine also. I don't have any of the "cruise control" effect going on. The only gripe I have is that coming to a stop <at 5mph and under> while the car is warmed up <doesn't do it cold> sometimes the idle will surge <dip then rev>. It will straighten itself out if I come to a complete stop. If I continue to coast/slow down, it will hunt up and down and surge until I stop or it stalls. I have the idle in gear set to 650, and idle in park/neutral at 700. I don't have any surging while driving over 5mph, only when coming to a stop or coasting under 5mph. Where should I start looking in order to correct this problem? From what I read the throttle cracker is what I should be changing? Any info would be appreciated!
Thanks!
