Originally Posted by
GAMEOVER
The last 3 trucks that I've worked on, the speedo-calculator has kicked my butt...:nixweiss:
The speedo fine tuning doesn't apply the changes when I plug in the values into the Displayed speed and actual speed. It shows the corrected value needed but doesn't show the new VSS pulses per mile or Km.
When I measure the roll out of the tire(circumference) and put in the values, the speedo calculator is usually right but...When a combination of bigger/taller tires and lower gear ratio's are used it's hit or miss...:(
I can usually get to within +/- 2mph but the ABS and Brake lights stay on...
