Im looking for a tuning file to do a segment swap to a 4l80E from my 4l60E on my silverado. either for a customs os 01250003 or original os 12202088 THANKS!!!!!
hyderm87, welcome to the forum...:cheers:
Some info:
If you could copy all your tables to a 12212156 file, it would be easier to do (and you could use COS5).Quote:
Mixed segment bin file tutorial :
showthread.php?t=9570
showthread.php?t=4621
showthread.php?t=5613
showthread.php?t=2151
what do you mean? the os number you gave me matches for a 2002 os how would i swap to a different base os??? Thanks
Basically you just need to find a vehicle that has a 4l80 in it, with the same os as yours, and copy the trans segment and paste it into yours.
yeah that is the problem im having is finding a os like mine with a 80 in it. so far no luck!!!!!
did you try holden crazy?
never mind
You can change OS by doing a full flash (after copying all the tables over).
FlashScan V2 can do this.
FlashScan V1 Commercial can do this... if you have V1 and it's not Commercial, then it's a $50 upgrade.
You may not easily find any files containing 12202088/4L80E.
It is easier to find files containing 12212156/4L80E.
Follow the links in post #2.
Thanks. i will try and let you know how it works out
thanks for all the help it worked!!!!!!
