Calc.BEN_xxxn - AutoVE using LM2
Versions:
EFILive v.7.5.5
FlashScan V1
Innovate LM-2
Using AutoVE process ...
I've done some searching and have come up dry. When using the external output on the LM2 and logging it in EFILive (V1) can I use the CALC.BEN_LM12 PID even though I am using an LM2 device ? I do not see an available PID for CALC.BEN_LM22 ?
BTW - I am also logging EXT.AD2 with what seem to be appropriate Volt values. Volts are consistently between 2-3.5 v, mainly in the 2.5 area (I believe 2.45 is stoich?). The leaner values are in higher RPM/Kpa sections.
My question is related to some odd behavior I have seen after looging this paticular BEN and getting values from 1.2 - 2.5 even though I have both lean and rich conditions. I am assuming these are high based on the AutoVE tutorial. I would expect values closer to .89 - 1.2.
Or do I need to create my own calculated PID maybe by changing the formula in sae_generic for LM1 to more accurately represent the LM2 hardware ?
Any advice is appreciated.
