how do i get rid of the codes after i take out the egr cooler help me asap
jim
jim
Did you disable the DTC's?
how do i do that i dont really mess with efi live that much
Go to table C6001 and disable all the EGR related codes. (P0401, P0402, P0403, Etc..)
how do i make a smoke tune
pretty full question. The rule behind any engine is to have fuel and air burning equally together to achieve a constant and controlled expansion inside the cylinder. The principal behind the smoke tune is to have a lot more fuel burning than air which creates the soot. So basically add fuel and keep the timing and boost tables the same.
What table is the fuel i understand how it all works but i just dont understand how to do it
Gotcha. Basically you will need to look at tables B1102 and B0720. Start increasing the pulse width on the bottom right side in increments. same with the commanded fuel. Do this at your own risk
