I heard that the 98 ls1 cars do not require the use of a license and that it has an unlimited use. I have the V2 flashscan. Is this true? thanks for info
You should have a 97-98 stream license (LS1-A) installed in your Flashscan device (V1&V2).
My V2 did not have it installed from the factory so I had to contact EFILive
for the license, it cost me nothing.
Thank u I am new at this so how do u know if the 97-98 stream license (ls1-a) is installed on my v2
Power up the V2 (OBD2 port or USB)
F4> F3> F3
LS1A should read Active.
Licenses can also be viewed with the software.
Connect the V2 to your PC and open the tune.exe or scan.exe
Help> Flashscan V2 Licensing> Stream Licenses
I have not heard of anyone else ever having the issue I did,
I'm sure it's very rare.
thank u going 2 try it now
It says S-ACT is active and the S-LS1A there is nothing there is that because i have not conneted it 2 the car
It just needs to be powered up.
Connect the V2 to a computer that has the software installed and either press:
F4> F3> F3 to view the details on the V2 itself or
open the software:
This is what you should see.
http://i235.photobucket.com/albums/e...S1A_Stream.jpg
my does not have active there. Should i click on add stream and type in activation code
Thank u 4 all your help
