Dpf delete
Whats up fellas i am asking this question for a friend of mine he has no computer he has done a dpf delete on his truck he has turned off any thing that has to do with the regen,dpf & did a egr blocker and turned off egr codes here is his ? will the ecm put the truck in LIMP mode because the ecm did not reconize a regen for a curtain amount of miles although he has did a dpf delete??? and what has to be done to keep truck from going into LIMP mode if it happens
Thanks Dave
Quote:
Originally Posted by
mr.prick
Are you saying if he has tured these codes off he wont have any issues
These are the parameters that have to be altered for DPF removal:
Change B2501 to No
Change B2502 to 0
Set the regen min engine temp to the max value (ie: higher than opperating temps)
__________________
47 trucks tuned since 2006 and still no clue what I'm doing , couldn't survive without the amazing support and quality of EFILive
