I just found this out today, GM.STATE0x is not in the filter drop down box.
I made a cal_pid for this. :)
That's what I do... (also, this way they can appear on a chart).
It's not easy to do, I had to search for a while before I found out how.
What's the secret?
The state PIDs have 8 "Bit Positions" and each have "RAW" value
Bit position 7 = 128
Bit position 6 = 64
Bit position 5 = 32
Bit position 4 = 16
Bit position 3 = 8
Bit position 2 = 4
Bit position 1 = 2
Bit position 0 = 1
Match the PID's Bit Position and RAW value and use
iff(RAW({GM.STATE00})&bit position,1,0)
Blacky explains it better here.
Why we need to go through this is a mystery to me,
it would be nice to have them defined in a way so they appear in the
The iff,& and bits :hihi: operators can be a handful for some people
to understand. (like myself) :doh2:
I recently discovered you can make a calc_pid for frame counts and
filter out/in a certain section of a log by frame numbers.
Call me slow. :confused:
For example, bit 5 can be extracted using either of these:
iff(RAW({GM.STATE02}) & 32, 1, 0)
RAW({GM.STATE02}) / 32 & 1
RAW({GM.STATE02}) >> 5 & 1
