small pulse adjust {B4005}
fuel/injectors/small pulse adjust
this table is (Msec, Msec),
therefor how does this table respond to larger injectors for example 60 Lbs siemens.
do the values increase or decrease from the stock values.
the one example that Ive seem, has this table with no proportionality to stock.
I would have thought that the larger injector requires more energy to turn on, and this table would be increased proportionally versus the stock values.
At cruise the car spends most of its time well into this table so I would think that it should have some impact on the fuel economy or stability of the AFR.
are there any examples for this table with 60# injectors (@58psi) or is this just not a significant for the tune?
thanks
