The table B1128 in the LMM OS only has 2 rows and the same table in the LBZ OS's has 16 rows. Thought you should know Ross.
These things happen from time to time, Bosch or GM decide to change table structures between models. The Duramax isn't too bad, the gas engines (E38, E67) are a nightmare between model years, tables disappear, tables are added and existing ones change structure.
This is a case of the table just changed structure. They must have thought it didn't need the resolution the LBZ had.
