please help tried to upgrade to DSP5 on lly
hi i have an 04 LLY i got the upgrade right and loaded it in the ecm with a full reflash. then tried to upgrade my V2 to use the serial switch and i cannot get the select PIDS to load LLY.ppm to my V2 from the efilive explorer. and i can't get on efi's website for some reason. my truck runs but i am worried i will not be able to work the computer properly. i followed the directions word for word off of efi's website. i formatted the flash memory in the V2 and then loaded the LLY.ppm and the AL5.ppm and the options.ppm and hit the refresh button to make sure they stuck. plugged in my ecm connection at the OBD II port and turned the key to on and all that fun stuff and my select PIDS says LS1 (sample),LS2 (sample), LBY (sample), and LLM (sample) no LLY or Manual LLY or AUTO LLY like in the directions. please help!!!!!!!
