Hi,
I need your opinion on the following tune:
Car is commodore 2007 auto trans, full bolt-ons, and 228/228 cam:
numbers are STD
http://img102.herosh.com/2009/12/03/649474303.png
Hi,
numbers are STD
Looks ok, why only start at 4000rpm though?
It seems to me: much too lean below 4500 to be safe under WOT load.
still... you should try to lock the converter with efilive and start tuning at 1500rpms at WOT. Honestly... you would get a lot of knocking down low.
I have delay in the wide band, I connected another one at the other tip, the result was 12.8 all the way!!
Are the hp & TRQ good?
