2kSilverado, Getting started, Need resources.
Third post, NEW here. :nuke:
I have done quite a lot of aftermarket real-time tuning. All closed systems, except Megasquirt.
I'm planning on learning EFI live by logging/tuning my stock daily driver(GASP!). It is a 2000 silverado w/ 5.3l,
Basic ideas below, are they sound?:
1- I think that makes it a LM-7... ?
2- I plan to go the MAF only, adjust the IFR, then go map only, auto VE, then connect both again and run closed loop(seems like the simple direct route).
3- Will perfect that tuned stock system for a while(also my methods).
Bigger Problem I would then like to flash a COS(learning and getting ready to turbo/LSx my old "97" fbody). My problem is that I haven't found ANY resources that will cross year/model PCM numbers and then cross to COS's. I have read a LOT and can't figure out what years/models/PCM#'s/internal flash #(whatever it's called)/memory amount/ and generation are used for custom applications. I basically only know about the (E40) and (e38) reluctors and other electrical requirements(schematic stuff).
Can anyone run a sanity check on my ideas? and/or Provide me with a source for the cross reference that I need(like the OLD!!! ludis pages).
Thanks in advance for any help,
S
