1 Attachment(s)
99 truck to OS12212156
I used a stock file from a 2002 Camaro 4L60E 5.7L and copied all my old values over.
What did I miss here? There are a few weird things happening:
Anti Theft - G1201 will not allow vehicle to run unless set to "none", and then the security light is on all the time. The other OS was fine with Class-2
Gear selection display no longer shows which gear is selected.
TCC control- D2801 will not lock on upshift.
Maybe using a stock 02 truck file will work better. There is one on HoldenCrazy.com. The F-car has a different theft system. Check the platform settings as well, they are different.
Al
Good call. The truck file fixed those issues. Thanks Al
edit: different problem showed up and I started another thread
http://forum.efilive.com/showthread.php?t=13664
