Hey guys I went to flash my stock PCM with my current tune from Wait4Me performance, and come to find out I have two different OS. The stock OS is 12585950 and the W4M PCM is running 12587603. The reason I was flashing the stock PCM with this tune is because I am sending the other PCM back to Jesse to tune for a cam swap and some other little things. I don't know enough about tuning yet that I feel comfortable tackling this.
So I searched for the correct OS for the stock PCM and the W4M PCM and was going to convert the stock PCM to the 04073003 COS. I didn't do any flashing with the new OS. I was trying to convert my tunes from one another and it wouldn't allow me to edit the COS. So what I did was I sat both tunes side by side and went through every file and copied the W4M tune to the stock PCM with the stock OS.
Is this an acceptable way of converting everything since it will be a temp tune? And is there anything that is hidden that I might have forgot? I will post up my stock tune, stock modified tune, and W4M tune if anyone wants to look them over and make sure I have everything.
It took about 2hrs to copy - paste everything. Thanks for the help.
