2 Attachment(s)
LC-1 WO2AFR Serial Reading Low AFR
I ran into a problem but I'm not exactly sure where it is. I need a bit of guidance. While testing serial logging of the LC-1 using BBX I had a AFR ratio hovering around 5% AFR (no alcohol in my tank).Right after sensor warm up free air was 20.8% in flashscan so my calibration should be good. My WO2EQ however was just below 1 around .98. I have attached my log from cold start to full warm. I still need to get my base airflow dialed in at <180*F but also check out the analog LC-1. It is correct as well. Do I have to perform a free air with the flash scan? I did free air with the led and push button.
Attachment 9888Attachment 9889
