a picture says a thousand words so check them out. Basically when i go to view my files they seem to be grouped with the same date and relatively similar times... it didn't used to do this any thoughts?
You didnt set the date on your V2, it doesnt have constant power so once you remove power it reverts back to whatever date/time you last programmed in. If you formatted and/or updated your firmware, it probably reset the clock. Use EFILive Explorer to program it, Im guessing EFILive V8 S&T does it too once you copy new config files over.
Ok, thanks. I remember looking around for that setting a while ago and not finding it but i'll give it another shot.
