Something has changed or I'm doing it wrong.
Ok, I'm trying to run scans that will help me adjust the spark table to lower the SA where I see big bursts of KR. I'd like to pull back the timing to reduce the KR pull of the ECM.
These are my PIDs
SAE.TP
SAE.MAF
SAE.ECT
SAE.RPM
SAE.FUELSYS
GM.HO2S11
GM.HO2S21
SAE.SPARK
SAE.IAT
SAE.MAP
SAE.LONGFT1
SAE.LONGFT2
GM.KR
SAE.SHRTFT1
SAE.SHRTFT2
SAE.VSS
Is there something else I need to select?
When I scan, I highlight the KR section and then switch to the Tune tool. All I ever see is a highlighted area way to the right in the 0.048 column and I think I should be much further to the left in the spark table.
Is there some kind of MAP needed?
If I ever get this thing working, I'll save the bloody thing as my default!
