Can I get a couple pid lists for these two controllers?
2009 Holden Commodore w/left-hand drive option. :hihi:
Depends on what you want to log....... ;)
Here's what I currently log via BBL.
It's been a while since I seriously logged a T43 though. If we were talking T42, then I use the following...Code:ECM, IAT
ECM, AAT
ECM, SPARKADV
ECM, MAP
ECM, VSS
ECM, ETCTP
ECM, APP
ECM, ECT, , -10:110:9:10:0
ECM, INVLVTMP_M
ECM, KNKRET, , 0.0:1.0:131:10:0
ECM, OCTSCL_M
ECM, MAFFREQ2
ECM, AIRPERSEC
ECM, MAF
ECM, APCYL_M
ECM, RPM, , 0:6200:66:10:0
ECM, AFRATIO_M
ECM, INJPWB1
ECM, INJPWB2
ECM, SHRTFT1
ECM, SHRTFT2
ECM, HO2S11
ECM, HO2S12
ECM, BRKR
CLC, BEN1_E38
Also the serial PIDs for the Techedge WB.
Code:TCM, ACCEP
TCM, RPM
TCM, TBASEPAT
TCM, VSS
TCM, GEAR
TCM, BRKR
TCM, SHIFTLAST
TCM, IAT
TCM, ECT
TCM, TFT
TCM, TRQENG_C
-, DYNTRQ
TCM, TCCP
TCM, TCCS
TCM, SHIFT34
TCM, SHIFT23
TCM, SHIFT12
-, DYNPWR
TCM, ADAPTCELL
TCM, ADAPTSHIFT
TCM, TURBINE
TCM, TFMDES
TCM, TFMCUR
TCM, TCSLIP
TCM, TCCSLIP
TCM, TFMDC
Simon
Thanks.
Nice car Simon, I always liked it. ;)
Is there a trick to reading the PCM?
I am getting bootloader rejected error.
The previous owner may have locked it because there is a CAI installed and
looking around other forums I find CAI & some type of lousy handheld flasher is popular with these vehicles. :bad:
The TCM read with no problems.
I take it you selected the E38 pid list prior to reading ?
I need an E38 with stock OS & calz for this car while I have the PCM unlocked.
The closer to AZ the better.
I have a stock 2009 Holden SS-V tune.... but it's about as far from AZ as you are going to get. Will that work for you ?
Simon
Edit: I should note that this is for an AFM / DOD motor, so it's an auto.
