I'm needing to do some temperature logging shortly on a new project. I have never used the thermal couple inputs on the V2 but know I have a need. Is there a recommended probe to use and what's different with the inputs on the V2 that are different from the analog 0-5v? Using them for coolant temperature checking so temp range is in the 150-250 range.
Thanks!
Howard
