1 Attachment(s)
Setting up for first log for calc vet tune.
Hi I am setting up for my first log for the Calc Vet tune, but I have a question in regards to my injector flow set up.
I have a stock LS1 out of a VZ Calais in my landcrusier. The information I got from the Marks4wd adaptor site suggested that I should run my fuel rail pressure @ 65psi. The holden work shop manual says that the pressure as standard is 59psi. Should I lower my pressure down to 59psi and keep the stock fuel injector flow rate setting or keep it at 65psi and change the fuel injector flow rate setting using the excel sheet that "RedHardSupra" created/found?
Also just to clarify, I do not have to disable my MAF for Calc Vet tuning, do I? Is that only if I was to use the Auto VE method?
Below is my current tune. The only real changes I have made is for the trani. I found that the stock tune was causing a too much flaring between shifts for my liking. I came across a tune from the VZ 2005 Adventura which was an all wheel drive Commodore. I noticed straight away the pressures were higher that my stock tune, so I copy and pasted all of the trani data into my stock tune. The difference in driving was evident right from the start. Now it shifts a lot smoother and does not drop down a gear as easily.
Please note that I have not made any of the adjustments that Shawn the Weatherman sugested in his CALC VET Summary Notes under "Calc Vet tuning tips" to the tune below. I have another copy of this tune that I have made those adjustments to that I will drop in before I start my logging.
Please feel free to scrutinize and provide feedback on any issues/concerns you may have. I am always greatfull for the help!
Attachment 12724
