Hi,
I have trailblazer ss 2006, i disconnected the front wheel shaft the car doesn't move at all. would you please advice if there is any solution.
Thanks,
Hi,
Thanks,
NOOOO!!! You cannot simply pull the front driveshaft on a TBSS, you will toast the transfer case! It is a Torsen T3 center differential so when you pull the front driveshaft, it pushes all the power to the front output. Thats why it doesnt move. Either remove the transfer case and do a RWD conversion or put the front driveshaft back NOW, otherwise you're going to end up spending a lot of $$ in repairs!
