*Error $0109
I recently updated my Autocal and now i get an error message, i can't even connect to EFIlive Explorer any more. The screen on the autocal is flashing. It shows i have the most recent updates but still got nothing.
*Error $0109
You need to program the latest firmware using the EFILive Control Panel. With the AC plugged in, open V8 S&T, then click the little FlashScan icon near the windows clock. Once that opens (should be EFILive Control Panel), then click F6 Firmware, then Update BootBlock. Once that is done, click Update Firmware. Should be all set.
Thank you this Wok't a treat. Thank help for you help :):)):):)
Glad you're up and running!
Hi,
I have same problem, after update my autocal screen flashing....... but i have last version and not possible reflashing again, in attach print screen.
Thanks !
Attachment 13240
Did you program the BBx config files...?
Hi,
I explain in detail.....
My client was updating the firmware (Scan&Tune V8.2.1 Build 197), as I was finishing to program fails.
After that, Autocal flashing screen and firmware appears OK.
You can tell me step by step how to fix or re-flash the firmware?
Thanks for your time
See the picture you posted in post #5 above... click BBx, then click Tuning, then create/modify the ECM list to include your ECM, delete others that you don't want, click Save, Click Program All (found by clicking down arrow next to Program button).
i have a new error has ane one come acros this one? so im trying to conect to the pcm in scen tool so i tyed 2 difent cars with the same resolt it will let me flash the pcm but not use the dashbord / darta log . any healp would be much appreciated
Error report generated by EFILive at 11:14:10 on Sep 09, 2012
Error code: ERR_RESPONSE/5
Response $0D: .
EFILive Version: 7.5.7 (Build 211)
Platform: Windows XP
Version: 5.1 (build 2600)
Processor type: Pentium 2295MHz
Directories
Temporary Cache: C:\Users\gippsta\Documents\EFILive\V7.5\Temporary cache
Logged Data: C:\Users\gippsta\Documents\EFILive\V7.5\Logged data
Customers: C:\Users\gippsta\Documents\EFILive\V7.5\Customers
Configuration: C:\Program Files (x86)\EFILive\V7.5\Configuration
Exported Data: C:\Users\gippsta\Documents\EFILive\V7.5\Exported data
Images: C:\Users\gippsta\Documents\EFILive\V7.5\Images
Sounds: C:\Users\gippsta\Documents\EFILive\V7.5\Sounds
Maps: C:\Users\gippsta\Documents\EFILive\V7.5\Maps
Pids: C:\Users\gippsta\Documents\EFILive\V7.5\PIDs
Virtual Dash: C:\Users\gippsta\Documents\EFILive\V7.5\VDash
Print Reports: C:\Users\gippsta\Documents\EFILive\V7.5\Print reports
Bug Reports: C:\Users\gippsta\Documents\EFILive\V7.5\Bug reports
Did you select the correct PCM/ECM (File->Select Controller)...?
