for the ls1a and ls1b ecm what will be the correct tooth count for those ecm to recognize or will it matter? i have both 24x and 58x stroker cranks and would like to know the correct wheel to use before assembly the computer os is 7603,2004 year model if that helps.... also any other information i should be aware of including years fo particular crank triggers, or maybe a simple answer as in it doesnt matter...
:nixweiss:
thanks in advance,
Benjamin
