EFI Live always shows D2 and Ingear, gear unknown Intermittent start issues
Hi. My 2005 LLY 3500 GMC Duramax has an intermittent start issues. Replaced Ignition SW, Key Cylinder, NSBU sw, and Starter relay. Starter is relatively new and I have checked, there is no voltage to starter solenoid when no start condition exists. All fuses have been checked. Very intermittent, when it's warm in shop, never fails. When Daughter has it at school or cold in mornings or evenings (Live in Alaska) it will not start. Last time, I moved shifter many times and when I went down in the neutral it started, so..I will look at cable. I did not have the special tool to align the NSBU but I was careful. I will see If I can borrow from local dealer. Perhaps readjust cable?
The EFI info has me concerned though:
before getting into EFI Live. In EFI live, Transmission PIDs I always have the following values even when changing gears:
Gear Selector: Value unknown
Park/Neutral Switch: INGEAR
Transmission Switch: D2
I have cleaned all connectors under the hood and now cleaning the PNP (NSBU) connector. I opened the hood and checking for bad wiring and I will trace the harness. I'm looking for insight / feedback.
Tks, Ken
PRI CAPTION DESCRIPTION VALUE UNITS MIN AVG MAX PARAMETER SYSTEM
1 BATTERY Battery Voltage 0.0 V 0.0 13.4 14.3 GM.BATTERY Transmission
1 VOLTS Battery Voltage 0.0 V 0.0 13.4 14.4 GM.VOLTS Battery
1 BIDI Bi-directional Response Code 0 Counts 0 0 0 GM.BIDI Diagnostics
1 RPM Engine RPM 0 RPM 0 672 1282 SAE.RPM Conditions
1 FFCOUNT Freeze Frame Counter 0 Counts 0 0 0 GM.FFCOUNT Diagnostics
1 FFNOTRUN Freeze Frame Not Run Counter 0 Counts 0 0 0 GM.FFNOTRUN Diagnostics
1 FFPASS Freeze Frame Pass Counter 0 Counts 0 0 0 GM.FFPASS Diagnostics
1 PRND Gear Selector Unknown . Unknown Unknown Unknown GM.PRND Transmission
1 GPFB Glow Plug Feedback Voltage 0.0 V 0.0 0.0 0.0 GM.GPFB Sensor
1 PRNDSW-PNPSW Park/Neutral Switch INGEAR . INGEAR INGEAR INGEAR GM.PNPSW Transmission
1 AUXIS-PTO_ON Power Take Off Active . SAE.AUXIS Conditions
1 AUXIS-PTO_OFF Power Take Off Inactive . SAE.AUXIS Conditions
1 TP Throttle Position 0.0 % 0.0 0.1 22.4 GM.TP Throttle
1 PRNDSW-TFPSW Transmission Switch D2 . D2 D2 D2 GM.TFPSW Transmission
1 AUXIS-UNUSED Unused . SAE.AUXIS Conditions
1 VSS Vehicle Speed Sensor 0 MPH 0 0 2 SAE.VSS Conditions
__________________
2005 GMC 3500 CC DRW.
