Today i tried the calcvet, im using a analog wideband..
Does this pids looks ok? and what about the log file? i will atach the current tune on the truck
when i try to aply the same data filter as the tutorial it deletes al the cells
Can you post your calc_pids.txt file.
Post a screenshot of your filter proprties.
Yeah sure, thank you very much really.
I'll look at it later today.
thank you. i think my wideand readings are rare.. i have an LC1 wide band but i cant use it on serial because the serial input of my efilive is melted, do you know where i can send my efilive to changue the serial input for a newone?
Is your FPR manifold-referenced or un-referenced...?
im not in US right now but i can send it if you tell me where i can send it
i have the fuel pressure regulator on the fuel rail but i dont have the vacuum hose conected to it, i think it is tuned for unreferenced manifold vacuum right?
