after you use your WB to make commanded=actual. Aside from burst knock what other issue can arise....
Mmm, what 'issues' do you have in mind??.
:D I dont have any other issues (not that I know of anyway) I am inquiring to see if there would be any problems I may be missing
Keep in mind that the value in each cell isn't an island- it relates to the cells around it. If a table looks like the Rocky Mountains, it may be difficult to achieve smooth transitions and you may wind up chasing your tail trying to correct a problem that exists simply because of the value gaps between adjacent cells.
