I've been reading all I can. From what I get ,as long as you tune from EQ/Lambda and have B3601 set to fuel,than it does not matter what afr is set at in lc-1. AFR is more like a guide or calculated. Is this correct? Do I need to set LC -1 Afr if I'm not using it to tune? Thanks.
