Cannot data log or view PID's with AutoCal
I was having intermittent rough idle issues on cold starts so Kory sent me a stock LMM file to load and log to compare the results.
Well when I went to flash the new stock tune onto the truck I received error $050B. After searching the forum I went in and selected only the LMM in the EFI Scan and Tune program under BBX (both F2 and F3) and hit program. This worked and allowed me to flash the truck with the stock tune.
I then tried to log the start up as Kory requested and then ran into the new issue. I hit okay on record data and then hit okay on the screen that shows "E35B LMM". After doing this the Autocal displays "ECM PILOT1TM" and does not start the timer like it use to when recording data. This message is also displayed when trying to just view the PID's.
Hopefully someone can help me out with this issue as I could not find anyone else that has reported this Autocal message before.
Chuck
